EX6200 V1: bricked DD-WRT Firmware with Update
3 posts / 0 new
malgates
malgates's picture
Hi Guys,
I was stupid enough to try to update my very old DD-WRT Firmware with the recommended latest build: https://dd-wrt.com/support/router-database/?model=EX6200_v1 v3.0 Beta Build 40559. I used to work very well, but now the device is basically a network switch. I cannot acces it via the web interface (previously it was only beeing used as an accesspoint and had a set ip.) I tried to do a factory reset, but it seems, that it does not do anything (pressed the reset button for a minute). The 30-30-30 method forces the router to reboot, but no chance to reach it.
Any suggestions?
Chris
ajdisse
ajdisse's picture
Had exact same issue,
Had exact same issue, updating from an old DD-WRT firmware to the version listed, seemed to brick my device.  Should've done mroe research and stuck with a kong build ratehr than native dd-wrt.
Ordering a ucb - rs232 cable to see if I can get it working agaiin
nate779
nate779's picture
This exact thing happend to
This exact thing happend to me, any solutions?
