I have a netgear r8000, can anyone recommend the best firmware for this model, I am currently on latest stock but have been looking at dd-wrt and openwrt. The router is mainly used for streaming.
The Latest Builds of DD-WRT have been working well and seem to be getting updated (supported) frequently. Current (Firmware: DD-WRT v3.0-r45632 std (01/31/21))
I have tried Tomato but I could not get decent (or even average) wifi speeds and the Ethernet connection kept reverting to 100mb's so I swithced to DD-WRT and It was better for speed but would spontaniously reboot, sad to say the best results were the Stock Firmware althoogh I miss Tomato the most.
bonjour
je me posais une question apres flash on peut toujours utiliser l'application Nighthawk sur android ou impossible
merci d'avance
https://dd-wrt.com/support/other-downloads/?path=betas%2F2021%2F01-31-20...
I have the Netgear AC3200 TRI BAND WIFI ROUTER
MODEL R8000
My biggest problem is that i am not able to log into the router.
I tried using the ethernet cable with the modem and through the App
I am fraustrated.
What other options do I have??
Thx
Matt
