Hi
it seems that my router no longer detects the connection of the rj45 cable ... the internet led which detects the internet connection no longer lights up and the integrated switch leds 1 2 3 4 no longer light up. I have the kong ddwrt firmware. Do you think I can catch up? should i try to do a factory update with the original netgear firmware to fix the problem or my hardware is down? the administration interface remains accessible only in wifi. telnet also works ...
Thank's in advance
in fact, The internet entry is not detected and the 4 switch outputs seem to be also inactive ... yesterday everything worked ...
