Bonjour à tous, désolé je traduis avec Google, je viens d'installer le dernier firmware voxel pour mon routeur pour se connecter au Vpn Nord mais j'ai lu le tutoriel du forum je ne comprends rien au départ si une personne peut m aider merci
Hello everyone, sorry I translate with Google, I just installed the latest voxel firmware for my router to connect to the North Vpn but I read the tutorial of the forum I do not understand anything at first if a person can help me thank you
To finish I managed with this method https://www.myopenrouter.com/article/how-set-openvpn-client-netgear-r9000-voxels-firmware
how to disconnect from vpn?
Disconnect the OpenVPN client by eg one of these methods
- Add a file with name "disable" to your USB-device directory "openvpn-client", and insert the USB in the router
- Enable Telnet and log in to the router and issue command: /etc/init.d/openvpn-client stop
Thanks my friends I searched for two days, would you have a solution to activate the vpn on an ip mmlage and autoconnect? thanking you
Thank you my friend your help I test it tonight when coming home from work thank you again
Ah not so much for me sorry no function edit on the forum, so here I can select what goes through the vpn or not just by checking the ethernet or the wifi can not adjust by IP address because I have an ethernet port who turns with a switch thank you for your help
You can preferrably try Router Mode.
Sorry I don't speak French.
hi all
kamoji : is there a way for the VPN to bypass a specific PORT ? (not an IP)
thanks in advance
I don't know, but you can try if using Voxels latest FW:
Create /root/firewall-start.sh and make it executable (eg with "chmod +x /root/firewall-start.sh"),
then add this to that file (for tcp on ports 1234 and 5678 - you might want udp ?!):
#!/bin/sh
iptables -t mangle -A OUTPUT -p tcp -m multiport --sports 1234,5678 -j MARK --set-mark 1
Reboot and see if it works. I have not tested this myself. I found this infomation via google
. So please try and report back.
Hello, why is my router disconnecting from openvpn when I log on to vpn on a computer?
Please read the readme 1st before asking in the forum. In the readme, it clearly explain how to connect/disconnecting vpn, how to bypass, etc.
