Just took this version last night and the apply buttons do not work when changing a setting. Specifically this is within the Wireless -> Basic setting, when changing between wirless netwok mode and also with wireless channels. I had to reboot the router after each setting change in order for it to register.
Do you have it installed on a v1 or v2?
@kentwoodie Did you click 'save' settings? In the guideline the behavior you explain, seems to be normal behavior. You MUST save your settings, or apply your settings before the buttons switch to new options. And when you click apply the router will restart.
