No internet connection with dd wrt firmware
8 posts / 0 new
JustDoIt
Hi there,
I have a linksys wag354 modem router which works perfectly well (dsl).
IP address is 192.168.1.150
I can access  the internet via wifi and ethernet connections.
I bought the NETGEAR 3500L router and did the 30-30-30 operation, then installed dd wrt firmware.
Thereafter I connect the Netgear router to the linksys modem-router.
 ip address set as 192.168.1.1
Netgear WNR 3500v2/U/L
DD-WRTv24 sp2 (12/07/09) mini build 13401M NEWD 2 k2.6eko
When I try to go on the internet, no connexion is available nor by wifi nor by ethernet.
What is the issue?
Many thanks for your help,
Tony
Brandon C
When you go to Status > Wan
When you go to Status > Wan does it show a WAN address?
http://192.168.1.1/Status_Internet.asp
And does you basic setup page show Wan Connection type as automatic?
JustDoIt
Hi Brandon, thank you for your support.
In, STATUS, I get the following for:
ROUTER
WAN DOMAIN NAME : domain_not_set.invalid
WAN
 Connection type is set as "Automatic Configuration DHCP"
 In Setup, clicking on "Basic Setup"
WAN Connection Type is "Automatic Configuration DHCP"
STP: Disable
On top of the screen, below firmware, in small white letters, there is the WAN IP 192.168.1.66
Hoping this information is useful, receive my kind regards,
Antoine
Brandon C
It should not be saying 192
It should not be saying 192.168.1.66 that is a LAN address.
You using a cable modem? Check and make sure the ethernet cable is plugged into the correct port in the router and modem.
Then power off/on the modem and see if that helps.
JustDoIt
My internet access is DSL.
I use the linksys modem router Wag354g and it works perfectly.
I have changed IP address to 192.168.2.1
The connection is PPPoA
DHCP is activated, start address is 192.168.2.64
When I go to 192.168.1.1, I access the DDR-WRT menu of the Netgear Router
STATUS => ROUTER TAG shows:
WAN Domain Name: domain_not_set.invalid
STATUS => WAN TAG shows:
Connection type: Automatic DHCP
IP address: 192.168.2.65
Gateway: 192.168.2.1
On top of the screen, below firmware, in small white letters, the WAN IP shows now 192.168.2.65
When I select the Linksys Modem-Router as wifi connection, internet works
However, when I select Netgear Wireless Router network, no internet connection is available...
I re-started both (Linksys modem-router and Netgear router) but there is still no internet connection via Netgear Router.
PS: Netgear Router is connected to linksys modem router via ethernet cable.
Linksys Ethernet port goes to Netgear Internet (Yellow) port
As you can see, I have changed the IP address of Linksys to 192.168.2.1 and Ip address of Netgear to 192.168.1.1 but the issue is still existing...
Thanks for your support
JustDoIt
I doublechecked above
I doublechecked above configuration and now the Internet connection works well with the Netgear router (wireless and ethernet).
Good step!
However, I cannot configure openvpn with this firmware. Is there an easy way to install a ddr-wrt version which supports openvpn?
Tony
JustDoIt
Actually I went on the dd-wrt
Actually I went on the dd-wrt.com website
Typing Netgear wnr3500L, I am getting several possibilties:
Mega, Mini, openvpn, standard, voip, usb, hotspot, ...
Which one is the most complete ( I need to use Openvpn and I have a voip phone as well)
kwbolte
See here for a comparison
See here for a comparison:
http://www.dd-wrt.com/wiki/index.php/What_is_DD-WRT%3F#File_Versions
The "big" oder "mega" builds should have mostly all options.
