I converted to dd-wrt to use a VPN service and now the SSIDs are not showing up for either the 2.4GHz or 5GHz channel. Not even the default versions. Any suggestions?
hopefully you sorted this out, but for anyone else asking the same question the SSID will broadcast as DD-WRT, you will have to rename the SSID's to separate the two, both default to just DD-WRT opposed to the original SSID's being Netgearxx-2.4 & neatgearxx-5
Website security can be a complex and even confusing topic because of its ever-evolving landscape, for that reason, it’s important to keep in mind that security (especially website security) is never a set-it-and-forget-it solution.
Why is website security important?
I should add that it is not broadcasting as hidden either.
I am experiencing the same issue. Have you managed to find a fix?
