OpenWRT 1.0 Source Code and Firmware no ssh not wan
2 posts / 0 new
alban
Hello
 I installed openwrt on my WGR614L v8, get well
GUI
The wifi  works well
 DHCP works well
 Test ping 192.168.1.1 Ok
Do not work
No WAN
No SSH
No Telnet
My lights are green and orange
 I can load the firmware from fedora 11 or Vista pro
Could  you tell me walked the tack, its very important
Thank you for  your help
hvanderheide
On my router I had to change
On my router I had to change the WAN interface in /etc/config/network from eth0.0 to eth0. But you might need a serial cable to make that change.
