I can't find any tutorial on how to get a USB drive working with the Kong DD-WRT firmware. I have the drive auto-mounted as follows:
Disk 0:
Block device, size 746.5 GiB (801569726464 bytes)
DOS/MBR partition map
Partition 1: 2.000 TiB (2199023255040 bytes, 4294967295 sectors from 1)
Type 0xEE (EFI GPT protective)
GPT partition map, 128 entries
Disk size 746.5 GiB (801569726464 bytes, 1565565872 sectors)
Disk GUID 4F24B4A6-E6BE-DA48-B27E-DD29375C832F
Partition 1: 128 MiB (134217728 bytes, 262144 sectors from 34)
Type MS Reserved (GUID 16E3C9E3-5C0B-B84D-817D-F92DF00215AE)
Partition Name "Microsoft reserved partition"
Partition GUID E59C8428-215F-254B-BC52-23171DDBF744
Blank disk/medium
Partition 2: 2.729 TiB (3000455135232 bytes, 5860263936 sectors from 264192)
Type Basic Data (GUID A2A0D0EB-E5B9-3344-87C0-68B6B72699C7)
Partition Name "Basic data partition"
Partition GUID 0B768B5A-51E5-3140-A13F-8114DE15346E
NTFS file system
Volume size 2.729 TiB (3000455134720 bytes, 5860263935 sectors)
Partition 3: unused
Mountpoints:
/dev/scsi/host0/bus0/target0/lun0/part1 mounted to /tmp/mnt/disc0-part1
That's wonderful. NOW WHAT? HOW THE [email protected] DO I ACCESS IT?
There are so many ways of accessing your usb drive, e.g. using ssh/WinSCP, FTP, Samba and Windows Network Neighbourhood etc.
you can find the thorough guideline of using those in the following link ...
http://www.dd-wrt.com/wiki/index.php/USB_storage#Step_4_-_Enable_Network...
Can't I just get it to show up on my Windows Network?
You should find your USB drive containt in "My Network Places" for Windows Operating System.
Following is a link of similar discussion ...
http://www.myopenrouter.com/forum/thread/32227/USB-How-to-get-it-working...
Hope it will help you.
Let us know about the result.
The problem is there is no path that I can select. When I click on the dropdown the only option is "--". Meanwhile under USB it still says my drive is mounted to
Mountpoints:
It's very frustrating.
Anyone?
So no one has an answer to this simple question?
Can you please give me the link to download the firmware you are using ??
