Return to Stock (Wireless stops functioning)
8 posts / 0 new
Bailx
Hi, I was running into an odd problem and was wondering if anyone had seen this before.
I was returning an R7800 from kong back to stock (which i've done on at least 2 other R7800 units without issues).
For some reason on this one, the wireless will not transmit once back to stock (no visible or hidden ssid).
i flashed over to brainslayers build and the wireless works there too.
i tried erasing manually in ssh
erase linux
reboot
then in tftp i put the netgear firmware back on
that way didn't work either.... so i wasn;t sure what to try next
(on the other 2 that reverted back to stock fine, the web gui with kong dd-wrt-to-netgear worked fine).
wireless starts working again if i reflash dd-wrt... but every time i take it back to stock it stops functioning (everything else seems normal).
thanks for any help.
even_miles
Hi. I've been testing Kong's
Hi. I've been testing Kong's DD-WRT in my R7800 and when I turn back to stock firmware I have encountered the same problem.
I think that some var in nvram is corrupt, but I don`t know what.
If I find the solution, I put here.
Bye.
even_miles
That's the trick:
That's the trick:
3) hard reset
Seen in https://www.myopenrouter.com/comment/39648#comment-39648.
Thanks to lobyte!!!
lobyte
Enable telnet: http://192.168
kajj88
Nowadays, such situations
Nowadays, such situations occur, you have to get used to it.
sources
sources
machrit134
The default router login
The default router login address for apple airport router, belkin routers and some d-link routers is 10.0.1.1 . Just simply enter your username and password in the field given in the login page to get into the admin settings of the router. For more details, read this post on how to login into 10.0.1.1
hagetivazo
mega downloader online ghdfh
mega downloader online ghdfh dfh dfh
swiftor
Hi, I'm encoutering what I
Hi, I'm encoutering what I think is the same issue - but when I do mtd erase overlay_volume I get a "Could not open mtd device: overlay_volume" message
