Seperating Wireless from Wired using DD-WRT and an R7000
4 posts / 0 new
phoomanchew
I have a R7000.  I would like to seperate the Wireless network from the Wired.  I do not want my wireless devices to have access to any of my wired devices.  I have read various articles and nothing seems to work correctly.
I have tried latest versions of both the Kong Mod and DD-WRT version with no luck.
Any guidance would be appreciated.
phoomanchew
Nothing?  Anything?
Nothing?  Anything?frown
phoomanchew
Okay, I believe I figured it
Okay, I believe I figured it out on my own.  Now I would like some feedback on if what I did was correct.  These settings seem to isolate my wired connections from my wireless connections.  Any feedback would be appreciated.
Go to the Setup->Networking tab
  • Under Port Setup, modify Network Configuration for eth1 or whatever your wireless is.
    • Set Bridge Assignment to Unbridged
    • Set Net Isolation to Enable
  • Under DHCPD, add a new DHCP server for eth1
    • DHCP1     eth1     On     Start     100     50     3600
Go to the Wireless tab
  • Under Wireless Physical Interface wl0
    • Set Wireless SSID Broadcast to Enable
    • Observe that Network Configuration should be set to Unbridged
    • Observe that Net Isolation should be set to Enable
Go to the Wireless->Wireless Security tab
  • Set Security Mode to WPA2 Personal
  • Set WPA Algorithms to AES
  • Set your WPA Shared Key to a very good password
Go to the Wireless->WLO-Advanced tab
Change AP Isolation to Enable
phoomanchew
Maybe this is not the correct
Maybe this is not the correct place to post this question.  Can someone please tell me where I can post this to get some feedback?  Thanks.smiley
