wireless rate fluctuation
9 posts / 0 new
Chronos300
I've been using DD-WRT for a while on my WRT54GS. However, I wanted to upgrade to an N router so I choose the WNR3500L. I was able to install DD-WRT without a hitch but I noticed from the get go my wireless rate was never really stable so I tweaked and played with my settings to no avail. Today I flashed to Tomato in the hopes of regaining the stability I had with my old 54GS but this problem still persists. Does anyone have any suggestion on how I can stabilize my wireless rate?
I'm on a network with a mix of wireless G and N devices if you need to know.
Sudipta
Have You tried with different
Have You tried with different channel? Default channel is 6. This may cause interferece problem with your neighbours.
Kong
Can you explain a bit more:
-what rates do you get
-how far away you are from the wnr3500l
-tx rate you are using
Chronos300
My apologizes.
My apologizes.
I usually get 5.5, 11, and occasionally 24mbps
I have a bunch of things connected but I fear the culprit might be my laptop in the basement which is one floor down and in a corner room.
I am using 40.
I'm on channel 3 also.
on a side not. I went back to DDWRT and it seems much more stable now. I am at a lose on what the issue is.
Kong
Since the wnr3500l has
Since the wnr3500l has internal antennas it may help if you experiment with different positions, see:
http://www.myopenrouter.com/article/18273/How-To-Maximize-Wireless-Perfo...
Chronos300
I tried making all the normal
I tried making all the normal adjustments and following the guidelines in the post but I'm still struggling. Right now I'm hoverng around 5.5-11mbps.
Kong
Is the laptops wireless card
Is the laptops wireless card a N or g model?
Your location is pretty much like mine one floor down through 30cm concrete with lots of steel in it, but even with only 2mW TX Power I get a perfect signal. But I'm using an N client card.
Chronos300
I actually replaced my unit.
I actually replaced my unit. I think that might have been the problem and I'm stable around 36mbps, which was normal for my old router too. The laptop supports G only but I'm probably going to upgrade to N sometime soon.
bigjohn
@edoc -
@edoc -
Yes, you can and should prioritize your 'work' pc's over the others.
You're running in Mixed Mode, which will result in fluctuation and less than N speeds to the N router. Get N 'usb' dongles for the G devices and put the network in N only mode for optimal performance.
John
