no it wont work -.-
damn
after the 30-30-30 reset still not working
what about new flashing???
in the boot up phase
i see that if i power on and connect to it the orange light next to the power light is on
-.- omg
i`m sorry -.-
i didn`t flash the original netgear before ...
but i told ddwrt to delete itself with 2 commands out of here ....
then i flashed tomato :S
should work ????
hmm well
i only have a jtag cable ^^
what about that?
hmm .. u need to have a usb-serial cable to access the console and see how far ur boot is happening properly ....
Most probably u have corrupted the flash n in the boot sequence u r not able to get the rootfs ...
these things will be clarified once u can access the console ....
what if i test out with my serial cable?? i know ir worked sometimes but i forgot the pinout of it ^^
is there a chance to destroy the board with testing the cable pinouts??
OK ... u first neeed to go through the spec of board to find its tx and rx pins ... Then coming to cable u can check using multimeter at two ends of the cable to find out its tx and rx pins ... then connect tx of board to rx of cable and vice versa and that shud do ....
let me know if u still have any doubts ..
basically one end of the cable shud be a USB end ....so from USB spec u know the tx and rx pin of d USB end ...
then using multimeter between USB end and other end of ur cable u can check out for the tx and rx pins ...
Do let me know if u need any further clarification ....
so i did this
now i can login into tomato i think but there is still an old password i think i tried different combinations :S
root admin
etc...
please help me
greets
ps.: i forgot to do "nvram get http_passwd" before :(
no it wont work -.-
damn
Oo
greets dominic
-.- omg
i`m sorry -.-
should work ????
hmm well
what about that?
i found a mobile phone cable ^^
but i dont now the polarity "bzw." the pinout
i have 3 cables...
some ideas?^^
greets
actually I havn't use a mobile fon cable for this purpose so can't say much abt it ...
I used my own usb->serial cable ....
U may find following information useful :
http://www.myopenrouter.com/article/10811/Hacking-Your-NETGEAR-WGR614L-H...
Let me know if u still have any doubts ...
greets
cant i test it with a multimeter???
some ideas?
greets ^^
testing with multimeter will be safe .... u can do that ..
and how????
"Then coming to cable u can check using multimeter at two ends of the cable to find out its tx and rx pins ... " how????? do you have IM ?
greets
i have a serial phone cable .... no usb i`m sorry :(
greets
OK ... then I think u will have to arrange a USB->serial cable .... I m not sure whether a simple serial cable will serve ur purpose or not ...
wich one should i buy???
A simple USB to serial cable ... It has been shown in the following article :
