Need to buy a new Router - Wireless N or G?
166 posts / 0 new
MyOpenRouter Team
Some questions I have regarding the purchase of a new router (mine broke):
I have to admit that I haven't been up on the latest in wireless standards lately.  Is Wireless N a standard yet, or should I stick with G?  My existing wireless connections are all built in to laptops, so I don't really have any legacy Wireless G technology that would go to waste.
I'm not a tinkerer, so probably wouldn't need an open source router, or would I?  Are there other advantages that should lean me in tha t direction?
I have a MediaSmart Server, so I'll be using the network heavily to stream video and audio as well as backup my devices.  I would love to do this wirelessly if possible.
Any thoughts, inputs would be appreciated!
Peter Redmer
This is really a great
This is really a great question. There's a lot of advantages to going with Wireless-N.
First off, you'll get up to double the speed (or more) of a Wireless-G connection, in theory. You may not need this speed for standard internet use, but it would be helpful when streaming HD video or playing demanding online games.
Second, you'll get expanded range from Wireless-N, again up to double or more of a Wireless-G product. NETGEAR's WNR2000 Wireless-N router claims up to 5X the range, and 15X the speed of a Wireless-G connection.
Also, if you get a dual-band Wireless-N router, you can take advantage of the 5 gHz band to help reduce interference from household devices.
The current devices are built on the 802.11n Draft 2.0. The draft is expected to be finalized in March 2009, so again in theory, upgrading to Wireless-N now will prepare you for the future. (See Wikipedia for more info on the specific updates to the status of the draft.)
In order to take advantage of it, though, you'll need to get Wireless-N adapters for your laptop/etc. Here are some examples.
And for your last question, should you buy an open source router? It depends on what you're looking to do. If you're not much of a tinkerer or a hacker, then an open source router may offer features that you don't need. I do like the DD-WRT firmware, but will openly admit that I don't really use the advanced features that it offers, at least not right now, since I mostly use it for simple internet access. So I think a standard router would work just fine for you, check out this one for starters.
It's a moot point, though, if you're looking for a Wireless-N router; I don't know of an open source router that supports Wireless-N. (The WGR614L is Wireless-G, for example.)
user294
My IMHO: if you have .n
My IMHO: if you have .n devices to use it with, .n router is a must. If you have no any .n devices, buying device with .n will not give you benefits but still good to have benefits in future.However .n support is not only a criteria to go.You may also want gigabit ports and\or fast CPU so router can really cope with routing and firewalling of all this traffic.I'm personally like USB jacks and will never buy device without USB since this extends device features set greatly.And so on.
DavidDinosaur
According to the DD-WRT
According to the DD-WRT website the WNDR3300 is supported by DD-WRT - not by this website, of course, since it is not WGR614L. See http://forum1.netgear.com/showpost.php?s=532cf94ecac15dcd5ed40841cbe4c57... or go to the "supported hardware" page through the tab on the main DDWRT page. I have no personal experience of this (yet).
Han
Maybe stupid question but
Maybe stupid question but will wireless N speed up/expand range of wireless G as well as all our laptops have wireless G inside but am not capable to reach max speed due too concrete/distance.
mercer
Similar question.. I have a
Similar question.. I have a wireless G router and wireless G cards in my 10 computers at work. If I get a wireless N router will I also need the G cards??
Peter Redmer
Good questions... to my
Good questions... to my knowledge, to reap the benefits of Wireless-N, you'll have to upgrade the cards in your laptop to Wireless-N type cards. Now, you should still be able to get a signal from your Wireless-N router on your laptops with the G cards, but you won't get the extra speed.
I'm thinking that you *might* still be able to benefit from the expanded range, though, even with the G cards - but I'm not 100% sure.
I'd love to hear some Wireless-N experts out there give us their thoughts... anybody?
Han
From what I understand so far
From what I understand so far, if you use Wireless N router and have wireless G cards installed in ur PC's/laptops you won't gain from either higher transfer rates nor wider wireless cover. Ie range wireless G will still be same as wireless G router. However am not an expert in this.
Goober
A quick questio, will the N
A quick questio, will the N standard improve wireless streaming of video over the network as at the moment im gettiing jumpy playback from my ReadyNas shared folders over G on VLC player. Could the N standard improve things?
Peter Redmer
I think it's possible that it
I think it's possible that it could improve streaming speed for you, but only if you have a wireless-N connection on the machine that you are streaming to.
So, if it's a laptop that you're using the VLC player to stream video to, you would need to get a Wireless-N card if it doesn't already have it built in. Otherwise, you won't get the benefits of Wireless-N.
Of course, it's not a guarantee that your speed will improve because of all the other variables, but there's a good chance it will help.
Goobe
Thanks for the reply and I
Thanks for the reply and I dont mean to sound picky but I would pefer to know for definate whether it would improve streaming on N standard to N standard devices before incurring any expense, If anyone knows for sure any advice would be appreciated.
Escalade1963
I guess I'm still a bit lost.
I guess I'm still a bit lost. How can I find out which router will work with my laptop. I have always used G, but N appears to be half the price. I dont really care about all the bells and whistles, just don't want wires running all over my floor. So, how can I check my computer and see which router will work. I have moved and bought a new laptop and also am wired right now. So its as if I was starting fresh. Thanks,Mark
gina
My router busted today. I
My router busted today. I have several devices (laptops, gaming systems, etc) using the wireless. However, only one of the 3 laptops used in my home have N capability (the laptops use the router more than anything - except when my son is home from college).
SO - I want to buy a new router with N capability, but the G devices must still be able to use them. Is N automatically backwards capable to G (understanding that the G devices will not gain the benefits). I just want to be certain that an N router will work with G devices.
And any suggestions on brands/models?
achilles
Yes you can use G devices
Yes you can use G devices with N router .... but u will not be able to avail features specific to the N standard ..... :)
Rest of the things will remain OK ...
Murali
Dear Peter, I have two
Dear Peter, I have two wireless routers. I want to extend the range by networking second wireless router to first wireless router in wirless mode. ( I want to connect second router to first router thru wireless and enxted the range).Can you help me out is it possible is yes how?
Dot
Boy this stuff is confusing.
Boy this stuff is confusing. I have a XP desktop in my office of my house that does not have a cable connection. I don't want wires running all over the place. Can I have a wireless N connected to my cable where my TV is downstairs and able to access the internet via cable in my office upstairs? Do I have to do anything to my desktop for it to use the wireless internet?
chrome009
wireless n if yu plan to use
wireless n if yu plan to use a wireless connection , it's much better than G standard
you can find top N wireless routers here : wireless router reviews
loverouters
I agree with chrome
I agree with chrome
alos,802.11 is finalized today and will be published in October .
so G routers will not be released in the future .
also there are cheap N routers with decent performance ,even cheaper than g routers .
take a look at TP-LINK TL-WR941ND Wireless N Router.
you can get it for 49$ and it offers an excellent throughput speed (one of the fatest routers in mixed mode(N/G))
i'm surprised also with the router range , i can get a stable signal for 300 feet away .
that's really great deal
achilles
thnx for d info ... I was
thnx for d info ... I was also in a dilemma abt whether to go for a N router or keep using G routers ....
This information has solved most of my queries ... :)
Oratiewowatte
* DELIVERED FAST!
* DELIVERED FAST!
* BEST QUALITY GENERIC DICATIONS!
* GUARANTEED THE 100% EFFECTIVITY AND REABILITY!
* NO PRESCRIPTION!
* CSTOMER SUPPORT AVAILABLE 24/7!
* BEST PRICES !
YOU CAN CHECK THE PRICES, AND THEN CLICK ON
ONE OF THE IMAGES BELOW TO PROCEED TO THE ORIGINAL PHARMACY SHOP.
18]Online Pharmacy - No Prescription
>>>PLEASE ENTER HERE
http://lifeert.supra-host.com/cialis.jpg
Cialis facts at Drugs.com
Cialis is used for:
Treating erectile dysfunction (ED). It may also be used for other conditions as determined by your doctor.
Cialis is a phosphodiesterase type 5 (PDE5) inhibitor. It works by helping to increase blood flow into the penis during sexual stimulation. This helps you to achieve and maintain an erection.
1buy canada cialis
1buy cheap cialis
1buy cialis
1buy cialis generic online
1buy cialis online
1buy generic cialis
2000 buy cialis daily f
2000 buy cialis daily feb statistics
20mg buy cialis
4.26 buy cialis
4.26 buy cialis online
8080 buy cialis viagra
approved buy cialis fda genuine
ball forging bed buy cialis
best buy cialis softtabs
best buys generic cialis pills
buy 1 cialis
buy 10 mg cialis
buy by cialis money order
buy canada cialis
buy cheap cialis
buy cheap cialis generic
buy cheap cialis generic levitra viagra
buy cheap cialis on the net
buy cheap cialis online
buy cheap cialis softtabs
buy cheap cialis without a prescription
buy cheap generic cialis
buy cheapest cialis
buy cialis
buy cialis 32
buy cialis australia
buy cialis buy cialis online dreampharmaceuticals
buy cialis by check
buy cialis by mail
buy cialis by the pill
buy cialis canada
buy cialis canadian
buy cialis cheap
buy cialis cheap prices fast delivery
buy cialis cheap us
buy cialis cheapest tadalafil tadalafil table
buy cialis cialas
buy cialis cialis
buy cialis cialis narod ru domain
buy cialis cialisnarodru
buy cialis cialisnarodru domain
buy cialis doctor online
buy cialis domain
buy cialis dream online pharmaceutical
buy cialis dreampharmaceuticals from online
buy cialis dreampharmaceuticals online
buy cialis drug online rx
buy cialis ebay find tadalafil
buy cialis fast shipping
buy cialis fda
buy cialis fedex shipping
buy cialis fioricet
buy cialis free shipping
buy cialis from icos
buy cialis from usa online
buy cialis generic
buy cialis generic pharmacy online
buy cialis grand rapids michigan
buy cialis href online
buy cialis huge discounts online
buy cialis in canada
buy cialis in south africa online
buy cialis in thailand by letters
buy cialis in the uk
buy cialis in uk
buy cialis line
buy cialis mail online
buy cialis money order
buy cialis narod ru domain
buy cialis next day delivery
buy cialis no online prescription
buy cialis now
buy cialis omline
buy cialis on line
buy cialis on line uk
buy cialis online
buy cialis online 20mg
buy cialis online 32
buy cialis online cheap
buy cialis online cheap pharmacy here
buy cialis online dream pharmaceutical
buy cialis online from canada
buy cialis online from dreampharmaceuticals
buy cialis online nopw
buy cialis online now
buy cialis online on sale
buy cialis online overnight
buy cialis online pharmacy
buy cialis online pharmacy online
buy cialis online rss feed
buy cialis online say wordpress
buy cialis online uk
buy cialis online viagra
buy cialis onlinebuy cialis online
buy cialis overnight shipping
buy cialis overseas
buy cialis pharmacy
buy cialis pharmacy online
buy cialis phentermine
buy cialis pill
buy cialis pills generic
buy cialis re
buy cialis shop tadalafil
buy cialis site
buy cialis soft
buy cialis soft tabs
buy cialis softtabs
buy cialis softtabs information
buy cialis softtabs online
buy cialis specialized cialis online pharmacy
buy cialis tadalafil
buy cialis tadalafil at horizon drugs
buy cialis today
buy cialis toronto
buy cialis uk
buy cialis viagra
buy cialis we
buy cialis where
buy cialis without a perscription
buy cialis without a prescription
buy cialis without prescription
buy discount cialis
buy discounted cialis softtabs
buy drug satellite tv buy cialis
buy generic 50mg cialis
buy generic cialis
buy generic cialis online
buy generic cialis overnight delivery
buy generic cialis softtabs
buy generic cialis softtabs cheap
buy generic cialis softtabs online
buy generic cialis uk
buy generic cialis without credit cards
buy generic cialis without prescription
buy now cialis
buy online cialis
buy online levitra cialis viagra
buy prescription cialis
buy prescription cialis online
buy soft cialis
buy softtabs cialis
buy sublingual cialis online
buy tadalafil cialis
buy tadalafil cialis online
buy viagra assist cheap cialis
buy viagra cialis
buy viagra cialis levitra
buy viagra cialis levitra online prescription
buying cialis
buying cialis generic mt
buying cialis in canada
buying cialis in uk
buying cialis online
buying cialis online guide
buying cialis review
buying generic cialis
buying viagra assist cheap cialis
canada buy cialis
canada buy cialis online
cheap cialis buy pharmacy online now
cialis best buy
cialis best price buy online
cialis buy
cialis buy cheap cialis online index
cialis buy cialis
cialis buy cialis generic cialis
cialis buy cialis online order cialis
cialis buy generic
cialis buy generic ed
cialis buy generic levitra
cialis buy it online huge discount
cialis buy on line
cialis buy online
cialis buy online cheap tadalafil
cialis online buy
cialis online buy adipex
cialis online buy cialis without prescription
cialis search buy tadalafil cialis
cialis to buy
cialis to buy new zealand
cialis uk buy
don't buy generic cialis
find buy tadalafil cialis at ebay
generic cialis best buy
generic cialis softtabs buy online
generic cialis tadalafil tadalis bestellen buy
generic cialis viagra caverta buy online
generic viagra cialis levitra buy cheap
is buying cialis on line legal
iwant to buy some cialis
pharmacy cialis buy
prices buy cialis cialas
search results buy cialis
search results buy cialis generic online
search results buy cialis online
the buy cialis
to cialis buy where
viagra cialis buy no prescription
viagra cialis buying guide
viagra cialis levitra buy viagra
where can i buy cialis
where to buy cheap cialis
where to buy cialis
where to buy cialis online
DavidT
I have a neighbor who is a
I have a neighbor who is a childhood friend. If we buy a wireless N router for his house would I be able to receive a reliable signal? The distance from my house to his is about 40-50 yards. It would be great to split the cost of internet service each month. :)
WILDJON99
I am thinking about buying a
I am thinking about buying a laptop with a Intel WiFi Link 5100 802.11 Wireless-N Mini Card but right now I own a wireless-G broadban router and wanted to know if I had to buy a new router or not.
harley
I have a lynksis router at my
I have a lynksis router at my apt. After a few weeks, I can't connect anymore. I changed the channel twice, it works for a while, then quits. I'm at a loss, what else can I do??
Lastlaugh
First of all, don't believe
First of all, don't believe all the hype when it comes to N routers. People like to quote things they see or hear on the Internet as fact, even though they have never tested any of it themselves. The 802.11N standard is an improvement over g, but not all it's hyped up to be. It does come with a speed increase, but no where near the 300-600mbps that everyone likes to quote. Try doing a file transfer with an n router, then try that same file over hardwired 100mbps Ethernet and you will see what I mean. Also, the 802.11n is still a 2.4ghz signal, just the same as b and g standards. There is really no significant range increase over g, and definately not b. And anyone who tells you to use the 5ghz band for range has no idea of radio propagation theory, because it doesn't have near the range of the 2.4ghz band. So, if you want an honest, educated opinion, then here it is:
if you are just needing it for web surfing and email, stick with g and don't look back. If you plan on doing and big file transfers, consider N, but know it's NOT as fast as hardwired Cat5e.
dheeraj
i have a wireless N card in
i have a wireless N card in my laptop will it work with a wireless G router?
Peter Redmer
@dheeraj: Yes, it should work
@dheeraj: Yes, it should work, but you won't get N speeds...
Jessica..
Hi(: i got a laptop for
Hi(: i got a laptop for christmas. an Hp i saw it in my moms closet..the thing is she doesnt no ANYTHING about computers. i just dont anything about the wirless internet.so would i have to get a router in order to go on the internet? i have a brandnew dell desktop too.so would that have something on it?i want to be able to go al through out my house and still be on the internet.so im not sure what to doo..? can you help and explain that?
Priest
I am looking to get a new
I am looking to get a new router. My entire home setup (save my Xbox 360) is G. I want to get N to start upgrading the rest of my PC's with N. Will my G cards in my PC's still pickup the N signal? Or is it not backwards compatible? Thanks in advance for the help.
Rick Ventix
Hello- I am looking to get a
Hello- I am looking to get a network hard drive. If I upgrade to an N router from my G, how much faster with the transfer speed be?
Rick
nilz38
Hi what is the maximum range
Hi what is the maximum range you would expect from a "G" /"N" Router!!!
nilz38
ultimately if you are looking
ultimately if you are looking at having upto 600MBps on your wireless network, stick with what you have, unless you have issues with wireless range. Now this would be a great Ideas for a HTPC!!!
