Hi Toastman!
Allows real time and 24 hour graphic monitoring per client. Per-IP traffic stats and history.
BCM SDK: 5.100.138.9: wireless driver in RT-N builds
PPP: single line MLPPP support
Support for Belkin F7D3301/F7D3302/F7D4301/F7D4302/F5D8235v3 routers.
Added support for USB led on E3000, WRT610Nv2, DIR-320, H-618B routers.
Various optimizations backports and fixes from upstream 2.6 kernel.
2) Has anyone used it?
3) Is it reliable?
...and why can't Netgear put way more than 16MB flash in these things? How about 512MB-4 GB? Flash is so cheap... I'd pay an extra few bucks for it and it would let us modders do so much more.
Hi Toastman!
thanks.
nm..
Answering some mail:
CONTAINING:
Good luck!
Hello Mr. Toastman,
What am I missing here?
Did you notice this?
TO TURN IT ON IF YOU NEED IT.
You will need to set up a static IP address on your computer to access the router and then change that setting if needed.
Toastman-RT-1.28.7488.2
Toastman:
3) Is it reliable?
d
d
Hardware: Netgear WNR3500L
