- While the "5 Easy Steps" 12 months 3 days ago
- R8000P would be grate to see. 12 months 4 days ago
- Have a R8000 but ordered a 12 months 4 days ago
Hi Toastman!
thanks.
nm..
Answering some mail:
Allows real time and 24 hour graphic monitoring per client. Per-IP traffic stats and history.
CONTAINING:
Good luck!
Hello Mr. Toastman,
What am I missing here?
Did you notice this?
TO TURN IT ON IF YOU NEED IT.
You will need to set up a static IP address on your computer to access the router and then change that setting if needed.
Toastman-RT-1.28.7488.2
Toastman:
2) Has anyone used it?
3) Is it reliable?
d
d
Hardware: Netgear WNR3500L
