- After the initial Kong Mod 12 months 2 days ago
pictures in this thread
next step was jtag,
Hi Guys,
--bill
Hey Guys,
Many Thanks
Hi
Thnx in advance :)
tobias.
Hey all,
Do this:
1) run router and wait 2-3
5) use result as password
Hi everyone,
You know why I'm here lol..
I have many questions.
I downloaded putty.exe
<Wait 5 min>
Full NVRam reset
<Wait 10 min>
nvram show|grep http
User: root
Celebrate...
Tinc has been a life saver...
Hello
Is it a useless idea?
CHeers
Thanks for any help
