Just FYI:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-...
Second release with hardware acceleration of OpenSSL.
Voxel,
Some constructive criticism of your work. Your firmware and development efforts are greatly appreciated by both myself and the community, however I have to call attention to a discontinuity in your work. You have, in addition to the firmware, written a 10 page plus guide to your firmware, which is great, However, you neglected or refuse (in my experience), to include what would be no more than maybe a dozen bullet points the steps to clearly setup and configure ssh. The outsourcing to an incomplete forum post does not address the issue long term, further the instructions are unclear and missing steps. I am sure you have people who know how to do this without hand holding but unfortunately I am a user who comes from firmware’s where ssh was configured as part of the build. That shouldn’t be the users job when it can be part of the compiling and solve it once and for all. I am sure it would not be a leap of faith for me to assume that you could configure your firmware to work with ssh clients out of the box like every other major firmware distribution, if not, your instructions as they stand are abysmal and reflect utterly poorly on what is stellar work. It’s not Eliz82’s job to do your job and her instructions had very sizeale gaps. You took the time to write a manual, to compile the firmware in special ways, why cut this corner? It is an important one and your cutting corners here leaves me befuddled.
I am sure you are not happy right now but understand this is constructive criticism and not destructive. I am a professor and would be as direct with them as I am you but I fail to grasp this discontinuity.
Dr. J
Voxel,
Will do, and please, understand tone is lost on here. I think what you are doing is awesome and your guide is fantastic. I will send you a PM over on SNB.
-JM
Hi everyone -- we increased the private message limit for everyone. Voxel and JM, let me know if this helps!
Thanks, much better. Could you please also think over possibility of editing already published posts?
Thanks Voxel, we appreciate the feedback on this. We can't turn this on for all members at this time but we're always looking at ways to improve the experience for everyone.
Hi Voxel, awesome stuff. Thanks so much for your skull sweat making this possible. You've got at least one more fan that understands that doing this for us, for free, in no way obligates you. In the words of an open-source mentor of mine, if it breaks I get to keep both pieces.
Just FYI:
Just FYI:
New release of my build.
New version of my custom firmware build: 1.0.2.46HF/1.0.2.46HF-HW).
Changes (vs 1.0.2.45HF):
1. OpenSSL is upgraded 1.0.2l->1.0.2m. Fixes (OpenSSL changelog):
* bn_sqrx8x_internal carry bug on x86_64 (CVE-2017-3736).
* Malformed X.509 IPAddressFamily could cause OOB read (CVE-2017-3735).
2. Changes in OpenVPN client:
* Now Power LED is blinking if router fails to connect to OpenVPN server.
* "--cd $OPENVPN_CONF_DIR" option is added to startup script.
3. Bug in openvpn-easy-rsa package is fixed (cert files regeneration, OpenSSL 0.9.8->1.0.0).
4. e2fsprogs package is upgraded 1.43.6->1.43.7.
5. curl package is upgraded 7.55.1->7.56.1.
6. ethtool package is upgaded 4.11->4.13.
7. wget package is upgraded 1.19.1->1.19.2.
8. iperf package is upgraded 2.0.9a->2.0.10.
9. libubox package is upgraded 2017-09-29->2017-10-06.
10. ubus package is upgraded 2017-02-18->2017-11-06.
11. libxml package is upgraded 2.9.6->2.9.7.
12. sqlite package is upgraded 3200100->3210000.
13. expat package is upgraded 2.2.4->2.2.5.
14. dnscrypt-resolvers.csv is updated.
15. Host tools: three components are upgraded.
16. Toolchain: Patch is added to compiler (to support compilation by gcc 6.3.0).
The link is:
Difference 1.0.2.46HF-HW vs 1.0.2.46HF: “HW” version means hardware acceleration of OpenSSL.
P.S.
This version does not include the fix for the WPA2 Vulnerability in bridge mode (the last is not released by NETGEAR yet).
The link is:
P.S.
Voxel, I just ordered the R9000 because I wanted a whole home VPN client, but at the same time wanted the PLEX server (my Raspi3 is terrible as transcoding). I found your firmware after about 2 hours of reading forums and I want to make sure I understand one of the comments you made about using Netgear source code to allow for Netgear features. You mentioned Plex in that list and I just wanted to verify that your firmware has both the added feature of OpenVPN client and the default Plex server capability.
Plex is included into my firmware. I know that people are using it, but I do not. My tests with Plex were just to see it is started and I can see its GUI in my browser. So I cannot say is it better than e.g. your Raspi3 or not ;-)
OpenVPN client is available too, right. But I have to warn that its installation is a bit unusual. You should read this nice article to get impression how to setup it:
https://www.myopenrouter.com/article/how-set-openvpn-client-netgear-r900...
Voxel, I need your help. I installed the firmware and everything seemed fine. I even posted in the OpenVPN topic it was working great. Well, I am not sure what happened. Two days after installing the firmware and using a VPN, I suddenly lost internet. I checked the router admin page and discovered that the admin page was saying there was no internet connection (the top left of the 6 boxes you get after you log into the router). But when I went directly to the Internet information, I had a green check for the WAN connection. I thought it had to do with the OpenVPN set up so I removed the VPN files and rebooted. I am still getting the no connection warning. I flashed back to the Netgear firmware and everything was fine and my service was restored. Thinking it was just a fluke, I re-flashed your firmware and again I got the no connection warning. With your firmware installed, I have rebooted the modem, the router, unplugged everything and plugged it back in...the whole typically gambit of troubleshooting steps.
What I don't get it that it worked fine for 2 days, and now no matter what I try, there just is no connection. I even tried DD-WRT and it worked with no issues (couldn't get VPN working). I am currently back on the Netgear firmware so I have a working router. I even tried the previous version of your firmware as well as the hardware acceleration version. What could be the issue? All this is happening without the VPN active so it isn't he OpenVPN client that is doing it.
Well, it's hard to say what's wrong. Even if your OpenVPN client fails to connect, the router should restore orogonal connection.
Let's step by step. First, your need just to have original connection (w/o OpenVPN client). BTW I do suggest to use HW version even if you do not use OpenVPN.
So flash latest HW version, then telnet to router and check that there are no files in /etc/openvpn/config/client:
rm -rf /etc/openvpn/config/client
then reboot your router and make hard reset. Restore your settings manually.
After this if you have ordinary connection proceed again with OpenVPN client. It is next step. Note: remove OpenVPN manually is just "rm -rf /etc/openvpn/config/client" and reboot.
If your OpenVPN client fails, check its log:
more /var/log/openvpn-client.log
Ok, I will try. I am out of my house for a few days while I have my floors refinished. I can tell you that once I realized the issue, I removed the OpenVPN files to test various firmwares and didn't even mess when them, but I was still getting the issues. But when I get back, I will post log/screen shots for what I was getting without the VPN files present.
New version of my custom firmware build: 1.0.2.54HF/1.0.2.54HF-HW).
Changes (vs 1.0.2.47HF):
1. Integration of changes from the stock v. 1.0.2.52:
https://kb.netgear.com/000053137/Se...on-on-Some-Routers-and-Gateways-PSV-2016-0131
Plus other changes including new versions of QCA drivers and TM QoS.
2. CVE-2017-15275 patch is added to samba.
3. Small improvements in samba config to increase the speed.
4. net-wall script is corrected to add possibility using own /root/firewall-start.sh script.
5. cron table potential problem is corrected (/etc/crontabs is now symlink to /tmp/etc/crontabs).
6. libsodium package is upgraded 1.0.15->1.0.16.
7. tar pckage is upgraded 1.29->1.30.
8. uci package is upgraded 2017-09-29->2018-01-01.
9. libubox package is upgraded 2017-10-06->2018-01-07.
10. e2fsprogs package is upgraded 1.43.7->1.43.8.
11. dnscrypt-resolvers.csv is updated.
The link is:
Important:
No reset is needed to upgrade from my previous versions. But: most probably you will need to do reset if upgrading from stock firmware 1.0.2.52 and above.
Difference 1.0.2.54HF-HW vs 1.0.2.54HF: “HW” version means hardware acceleration of OpenSSL.
New version of my custom firmware build: 1.0.3.8HF/1.0.3.8HF-HW.
Changes (vs 1.0.3.7HF):
1. WIGIG firmware (AD driver) is reverted back to previous version (fixing problems with 802.11ad).
2. Bug in ReadySHARE GUI (Advanced Settings, Apply button) is fixed, problem reported by tech960.
3. ubus package is upgraded 2017-11-13->2018-01-16.
4. HW version: cryptodev-linux package is upgraded 1.9.git-2017-05-29->1.9.git-2017-10-04.
Changes (1.0.3.7HF vs 1.0.2.54HF):
1. Integration of changes from the stock v. 1.0.3.6.
2. Several bugs in the stock v. 1.0.3.6 are fixed (ReadyCLOUD link in WebGUI, aws-iot, etc.).
The link is:
Important:
P.S. It is recommended to disable Router Auto Firmware Update. Otherwise your router might be upgraded suddenly by stock version.
Difference 1.0.3.8HF-HW vs 1.0.3.8HF: “HW” version means hardware acceleration of OpenSSL.
hello. i was updated my router with yours latest FW 1.0.3.8 HW, but PLex APP wont start. it's say :
I have try'd evrything but PLEX wont start, untili when upgrade on offiicial FW again.
mitko25
I checked right now with 1.0.3.8HF-HW: I was able to install and start Plex. IMO you should remove Plex and install it anew. How (some manual job).
1. Disable Plex from WebGUI
2. Enable telnet from //routerlogin.net/debug.htm page.
3. Enter by telnet to your router.
4. Run the command from telnet console:
rm -rf /tmp/plexmediaserver/*
After that try to enable Plex in GUI and wait some time.
It works for me.
New version of my custom firmware build: 1.0.3.11HF/1.0.3.11HF-HW.
Changes (vs 1.0.3.9HF):
1. Integration of changes from the stock v. 1.0.3.10.
PSV-2017-3167 http://kb.netgear.com/en_US/000055193/
PSV-2017-3093 http://kb.netgear.com/en_US/000055191/
NOTE: reset is needed!
2. Some NG bugs are corrected.
3. OpenVPN client is optimized.
4. OpenSSL configuration is changed to provide compatibility with ReadyCLOUD 20170711.
5. OpenVPN is upgraded 2.4.4->2.4.5.
6. dropbear package is upgraded 2017.75->2018.76.
7. util-linux package is upgraded 2.30.2->2.31.1.
8. iperf package is upgraded to iperf3 2.0.10->3.4.
9. Beta support of R8900.
The link is:
Important: reset to factory settings is needed after flasing.
Thanks Voxel this firmware is exactly what I have been looking for and works like a charm
New version of my custom firmware build: 1.0.4.3HF/1.0.4.3HF-HW.
Changes (vs 1.0.3.12HF):
1. Integration of changes from the stock v. 1.0.3.16/1.0.4.2.
2. NG version of OpenVPN client is removed (use my version if necessary).
3. Several NG bugs are corrected.
4. New samba CVE patches.
5. OpenVPN is upgraded 2.4.5->2.4.6.
6. liblz4 package is upgraded 1.8.1.2->1.8.2 (general speed improvements, see https://github.com/lz4/lz4/releases).
7. at package is upgraded 3.1.13->3.1.20.
8. libubox package is upgraded 2018-03-21->2018-04-12.
9. ca-certificates package is upgraded 20170717->20180409.
10. sqlite package is upgraded 3210000->3230100.
11. wget package is upgraded 1.19.2->1.19.5.
12. curl package is upgraded 7.59.0->7.60.0.
13. ethtool package is upgaded 4.15->4.16.
14. cifs-utils package is upgraded 6.6->6.8.
15. Host tools: several components are upgraded.
The link is:
No reset to factory is needed after flasing from 1.0.3.12HF/1.0.3.12HF-HW.
Difference 1.0.4.13HF-HW vs 1.0.4.13HF: “HW” version means hardware acceleration of OpenSSL.
Has anyone figued out yet how to fix the LAN connection dropping issue? Every few days all my LAN ports just die and I have to reboot the router to get them communicating again. Wireless is not affected.
Same issue here. Just moved to DD-WRT to see if that'll solve it
Hi Voxel
I have tried every combination to get my VPN working but i have had no luck whatsoever.
I cannot connect wirelessly with it enabled. I have all certificated in openvpn-client directory in root of usb containing 4 files:
auth.txt, ca.rsa.2048.crt, crl.rsa.2048.pem and manchester.ovpn.
I have followed the guide here:
Please advise?
So it is resolved, right? SNB forums.
