I replaced the Netgear firmware in my R6400 v1 because I wanted to use Nord VPN. Could not get the VPN service to work properly so I canceled it. The DD-WRT (build 36527) does not support the USB functionality on the R6400 so I want to replace it. I have not been able to replace the DD-WRT firmware with Netgear, which would be my preference. Is there firmware I can flash that will allow me, as an interium step, to get to get back to Netgear or at least will support the USB functionality?
- After the initial Kong Mod 12 months 2 days ago
Try using the Initial .chk firmware file from the Netgear support site.
i tried to flash my r6400 v1 but failed, disconnected from the net half way thru. is there anything I can do to at least set it back to factory firmware or should i just toss it. if anybody can help me with this i'll thank you ahead of time.
