"The Firmware Is Not Compatible With Your Router" Error
70 posts / 0 new
mikeloeven
mikeloeven's picture
We shouldn't have to go down
We shouldn't have to go down the rabbit hole like this not everyone who uses DD-WRT wants to risk a serial connection especially when the router is under warrenty and the screws are under the sticker .....
Cyfer522586
Cyfer522586's picture
Shit i got  the same error,
Shit i got  the same error, this is a pain in the ass. I have tried everything and since 3 months now i've been fucking around that router to flash it with dd wrt. Does someone know a solution which is not too complicated??
mikeloeven
This needs to be resolved it
This needs to be resolved it cant be that hard to release a new initial flash packge with updated board id's and version numbers to match the genie's version check
mrdon213
mrdon213's picture
There are new Init files for
There are new Init files for Freshtomato that should work.
manicdefender
manicdefender's picture
Or you can flash a pre
Or you can flash a pre-patched version of OpenWRT which allows you to then use whatever firmware you wish to. A link to it is about half way down the page on the DD-WRT forums. Can confirm it worked on mine.
https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=315110&postdays=0&postorder=asc&start=30
notestein
notestein's picture
Just got the router today and
Just got the router today and flashed it using this method.    But with some modifications...
1. Flash openwrt-bcm53xx-netgear-R8000-squashfs.chk in DD-WRT using Netgear web gui.
2. ssh into the router with
Code:
ssh [email protected]
There is no password so you'll go right in.
3.  Plug a network cable from your existing router/cable modem/etc that provides DHCP address leases into the WAN port and use ifconfig to check until you see one of the ports pick up a DHCP address. You can do that with
Code:
ifconfig
4.  Assuming you get an IP and can get to the internet (
Code:
ping 8.8.8.8
from the ssh prompt will tell you) at this point we need to install and enable the web interface
Code:
opkg update (had to keep rerunning to get all the packages down)
opkg install luci (had to keep rerunning to get the install complete)
/etc/init.d/uhttpd start
/etc/init.d/uhttpd enable
mv /etc/config/luci.bak /etc/config/luci (added by me)
5.  If that worked you can access the device with http://192.168.1.1
factory reset (added buy me)
http://192.168.1.1/start.htm (if you get the luci screen which I did)
http://192.168.1.1/index.asp (I had to explicitly add index.asp as the default was going to the Luci themed interface
6.  Go through the initial setup prompts and then flash your http://www.desipro.de/ddwrt/K3-AC-Arm/dd-wrt.K3_R8000.chk firmware. Power cycle the device and you should be able to access it via http://192.168.1.1 with DD-WRT working as expected.  Maybe should use the .bin
mikeloeven
LUCI failed to install with
/usr/lib/lua/luci/dispatcher.lua:247: /etc/config/luci seems to be corrupt, unable to find section 'main'
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:247: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:144: in function </usr/lib/lua/luci/dispatcher.lua:143>
attempted a few fixes and ended up with a boot looping router. waiting on a serial cable to ship now any ideas whats going on here ?
mikeloeven
but THIS is exactly the
but THIS is exactly the reason kong needs to release a pached dd-wrt too many potential points of failure with a roundabout instalation method like this
mrdon213
mrdon213's picture
KONG is no longer doing DD
KONG is no longer doing DD-WRT he moved to OPENWRT. There is a Tomato INIT file that will work!
