- After the initial Kong Mod 1 year 5 months ago
- Working the EXACT same 1 year 5 months ago
- While the "5 Easy Steps" 1 year 5 months ago
- R8000P would be grate to see. 1 year 5 months ago
- Have a R8000 but ordered a 1 year 5 months ago
The link is:
The link is:
Hello Voxel,
Thanks in advance.
Start/stop Plex:
Voxel,
Hi.
Sorry for my poor english.
Yeah, I know. See above.
The link is:
opkg update
Collected errors:
Voxel I'm new here and to flashing routers. I was wondering why it seems to be that you don't install your firmware the same as the others? I have a r9000, there's a lot talking about your work, but I can't figure out how to install by what you are saying. Is it me?
Danser
2. Unpack it, you will get the file r9000-V1.0.4.15HF-HW.img
5. Use the button [Browse] to select the file r9000-V1.0.4.15HF-HW.img and then click [Upload]
From WIKI:
for details.
The link is:
The link is:
Changes (vs 1.0.4.30HF):
The link is:
Changes (vs 1.0.4.31.1HF):
8. zlib package is optimized.
The link is:
Changes (vs 1.0.4.32HF):
1. QoS DB is updated to v1.58
The link is:
