Custom firmware build for R9000
71 posts / 0 new
Voxel
Voxel's picture
New version of my custom
New version of my custom firmware build: 1.0.4.5HF/1.0.4.5HF-HW.
The link is:
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.6HF/1.0.4.6HF-HW.
1. uhttpd: Fix for Attached Device Names is included (similar to r7800).
The link is:
molano
molano's picture
Hello Voxel,
Hello Voxel,
I am a happy user of your firmware for a couple of months now.  I just have some questions which I hope you can answer...
- Is it normal that I loose my openvpn-settings, dnscrypt and ssh access after every firmware update?  Is there anything I can do to make it persistent...?
Thanks in advance.
Voxel
Voxel's picture
Start/stop Plex:
molano
molano's picture
Voxel,
Voxel,
Thanks for sharing.  Howerver, the plexcommands does not seem to work.  I got no output so it seems the script runs fine, but when I stop plex with commandline, I am still able to access it. Also the webUI still shows plex as running.
I got one additional question:  In your readme, it says how to disable cloudready, but it does not really explain how to remove the bits.  Can you please explain?
molano
molano's picture
Drop the plex thing.  Seems
Drop the plex thing.  Seems to be working, but you need to give the full path when running cmdplexmediaserver.
bytears
bytears's picture
Hi.
Hi.
Sorry for my poor english.
I'm successfully setup Voxel's 1.0.4.6HF-HW version firmware and Entware.(Thanks Voxel.)
Voxel
Voxel's picture
farenheit
farenheit's picture
Just received an email from netgear advising of a new firmware .12 :)
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.13HF/1.0.4.13HF-HW.
Changes (vs 1.0.4.6HF/1.0.4.6HF-HW):
1. Integration of changes from the stock v. 1.0.4.12.
2. stubby package is added (with all needed dependences) to provide DNS-over-TLS support:
to enable stubby run the commands from telnet/ssh console:
nvram set stubby=1
nvram commit
and reboot your router; to disable stubby run the commands from telnet/ssh console:
nvram set stubby=0
nvram commit
and reboot your router.
3. Temporary fix for NG's bug (Attached Device List) is removerd (is working now).
5. dbus package is upgraded 1.12.8->1.12.10.
6. expat package is upgraded 2.2.5->2.2.6.
7. liblz4 package is upgraded 1.8.2->1.8.3.
8. ethtool package is upgaded 4.17->4.18.
9. curl package is upgraded 7.61.0->7.61.1.
10. at package is upgraded 3.1.20->3.1.23.
11. sqlite package is upgraded 3230100->3240000.
12. sysstat package is upgraded 11.0.4->11.6.4.
13. HW version: mbedtls package is upgraded 2.12.0->2.13.0.
14. plexmedia package: some re-order.
15. Host tools: several components are upgraded.
16. /etc/profile default profile is changed (no PATH for /opt/bin:/opr/sbin).
Entware users should set the PATH for Entware in /root/.profile file.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
So important notes:
1. stubby (DNS-Over-TLS) is already included into firmware. To enable stubby run the commands from telnet/ssh console:
nvram set stubby=1
nvram commit
nvram set stubby=0
nvram commit
and reboot your router. Currently it is configured to use Cloudflare servers (DoT). You may customize your config file:
/etc/stubby/stubby.yml
2. Info for Entware users. /etc/profile default profile is changed (no PATH for Entware is set by default, i.e. /opt/bin:/opr/sbin). Set the PATH for Entware in /root/.profile file, something like:
export PATH=/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin
Difference 1.0.4.13HF-HW vs 1.0.13.6HF: “HW” version means hardware acceleration of OpenSSL.
Voxel
Voxel's picture
Yeah, I know. See above.
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.14HF/1.0.4.14HF-HW.
The link is:
BigWhoop
BigWhoop's picture
Iam on V1.0.4.14HF-HW and
opkg update
Collected errors:
jsonman
jsonman's picture
Hi Voxel, I want to  switch
Hi Voxel, I want to  switch to your firmware from DD-WRT (wish I would of seen you kept settings before going with them) but few questions.
1. Does your firmware have a tool to monitor outbound bandwith usage?  Comcast is saying I'm going over my data and stock NG firmware sucks for tracking usuage
2. On the download page what is the diffrence between the hf and hf-hw .zip/image files?  Which one would be needed for someone going from stock to your firmware?
Voxel
Voxel's picture
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.15HF/1.0.4.15HF-HW.
Changes (vs 1.0.4.14HF/1.0.4.14HF-HW):
1. OpenSSL package is upgraded 1.0.2p->1.0.2q.
2. DNSCrypt Proxy v.2 (2.0.19) is included into firmware:
to enable DNSCrypt Proxy v.2 run the commands from telnet/ssh console:
nvram set dnscrypt2=1
nvram commit
to disable DNSCrypt Proxy v.2 run the commands from telnet/ssh console:
nvram set dnscrypt2=0
nvram commit
and reboot your router.​
3. unbound package (used in stubby) is upgraded 1.8.1->1.8.2.
4. wget package is upgraded 1.19.5->1.20.
5. util-linux package is upgraded 2.32.1->2.33.
6. haveged package is upgraded 1.9.2->1.9.4.
7. ethtool package is upgaded 4.18->4.19.
8. libjpeg package is upgraded 9a->9c.
9. curl package is upgraded 7.61.1->7.62.0.
10. libgcrypt package is upgraded 1.8.3->1.8.4.
11. libubox package is upgraded 2018-07-25->2018-11-16.
12. sqlite package is upgraded 3240000->3250300.
13. HW version: cryptodev-linux package is upgraded 1.9.git-2017-10-04->1.9.git-2018-11-02.
The link is:
nvram set stubby=1
nvram commit
nvram set stubby=0
nvram commit
2. DNSCrypt Proxy v.2 is already included into firmware. To enable DNSCrypt Proxy v.2 run the commands from telnet/ssh console:
nvram commit
nvram commit
and reboot your router. Currently is is configured to is Cloudflare, ipredator, scaleway-fr, dnscrypt.eu-nl, dnscrypt.eu-dk. You may customize your config file /etc/dnscrypt-proxy-2.toml to add/remove your selected servers.
3. If both (stubby and DNSCrypt Proxy v.2) are enabled, stubby has highest priority (it will shutdown all dnscrypt (v1 and v2)). DNSCrypt Proxy v1 if still used has lowest priority.
Difference 1.0.4.14HF-HW vs 1.0.4.14HF: “HW” version means hardware acceleration of OpenSSL.
Danser
Danser's picture
Voxel I'm new here and was
Voxel I'm new here and to flashing routers. I was wondering why it seems to be that you don't install your firmware the same as the others? I have a R9000, there's a lot talking about your work, but I can't figure out how to install by what you are saying. Is it me?
Danser
Voxel
Voxel's picture
Danser
Danser's picture
No, I'm sorry by not
No, I'm sorry by not conveying my thoughts and a better way of making any sense. Thank you Voxel for coming back. I have never flashed a router other than to flash updates from Netgear and want to use yours when you get to the RC version of the file. Do you have any idea when that may be? Are you going to produce a Youtube and steps to flash with your file? You out of maybe ten came back to say anything. I have asked what file to use when flashing my router. Usually, there are two, .bin and img. What's the difference? Can I use an external USB drive attached to the router to flash with your img file? All I've seen is an ethernet cable. So many questions I know and if you have the time to answer them, you won't only be helping me, but whomever may run upon this post.
Thanks again
Danser
Voxel
Voxel's picture
It is a bit problematic for
It is a bit problematic for me to understand you. What do you mean under "RC version of the file"?  I do use as a base for my build official GPL source codes of a stock firmware.
5. Use  the button [Browse] to select the file  R9000-V1.0.4.15HF-HW.img and then click [Upload]
To revert back to stock download the file http://www.downloads.netgear.com/files/GDC/R9000/R9000-V1.0.4.12.zip (it is official latest stock firmware file), And do similar to flash IMG stored in this archive. You will get a router with official NG firmware.
Danser
Danser's picture
Basically where your file is
On the (RC). Basically where your file is now.
From WIKI:
A release candidate (RC), also known as "going silver", is a beta version with potential to be a final product, which is ready to release unless significant bugs emerge. ...
On the USB stick, or ethernet cable. Can either be used to flash the file? On the reset. How do you accomplish it? I think you said somewhere not to use the 30/30/30.
Danser
Danser's picture
Nevermind got to thinking about it and I'd say no with the USB.
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.16HF/1.0.4.16HF-HW.
(NOTE: This release does not contain integration of latest stock firmware changes. Too many negative feedback (issues) for release of the stock firmware. But there are several fixes of security issues so it has a sense to perform upgrade from previous version. Thus it is intermediate maintenance release to provide synchronization of changes for r7800.)
for details.
The link is:
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.27HF/1.0.4.27HF-HW.
  • a login password enhancement in the router web interface to support a more secure password (no saving passwords in NVRAM in plain text form).
  • fixing the issue where the speed test in the QoS page always fails.
  • Dynamic QoS database v1.46 update.
The link is:
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.29HF/1.0.4.29HF-HW.
Changes (vs 1.0.4.27HF/1.0.4.27HF-HW):
1. Integration of changes from the stock v. 1.0.4.28.
2. dropbear package is upgraded 2018.76->2019.78.
3. OpenSSL package is upgraded 1.0.2q->1.0.2r.
4. OpenVPN is upgraded 2.4.6->2.4.7.
5. DNSCrypt Proxy v.2 is upgraded 2.0.19->2.0.22.
6. unbound package (used in stubby) is upgraded 1.9.0->1.9.1.
7. ca-certificates package is upgraded 20180409->20190110.
8. libubox package is upgraded 2018-11-16->2019-02-27.
9. tar package is upgraded 1.31->1.32.
10. libgpg-error package is upgraded 1.34->1.36.
11. busybox package: dos2unix/unix2dos commands are added.
12. proftpd: read access issue for admin user is fixed (NG bug).
13. Toolchain: binutils version is upgraded to 2.32.
The link is:
Difference 1.0.4.29HF-HW vs 1.0.4.29HF: “HW” version means hardware acceleration of OpenSSL.
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.30HF/1.0.4.30HF-HW.
Changes (vs 1.0.4.29HF/1.0.4.29HF-HW):
1. ffmpeg package is upgraded 3.4.5->3.4.6.
2. cifs-utils package is upgraded 6.8->6.9.
3. wget package is upgraded 1.20.1->1.20.3.
4. sqlite package is upgraded 3260000->3270200.
5. getdns package (used in stubby) is upgraded 1.5.0->1.5.2.
6. stubby package is upgraded 0.2.4->0.2.6.
7. DNSCrypt Proxy v.2 is upgraded 2.0.22->2.0.23.
8. curl package is upgraded 7.64.0->7.64.1.
9. HW version: mbedtls package is upgraded 2.16.0->2.16.1.
10. libusb package is added (v. 1.0.22).
11. libusb-compat package is added (v. 0.1.5).
12. mp707 package is added (v. 1.0.2-20171025).
13. Typo bug in OpenVPN client (led control in ovpnclient-down.sh script) is fixed.
14. congestion control algorithm is changed to westwood+.
15. rmem_max/wmem_max/defaults values are decreased to avoid bufferbloat issues (note: use QoS and limit your max speed for good results in dslreports).
16. DNSCryps Proxy V1 and its dependence libsodium are removed.
17. net-wall: cosmetic changes.
18. cmdftp: cosmetic changes.
19. Host tools: now default host cmake is used.
The link is:
Difference 1.0.4.30HF-HW vs 1.0.4.30HF: “HW” version means hardware acceleration of OpenSSL.
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.31HF.
Changes (vs 1.0.4.30HF):
The link is:
Voxel
Voxel's picture
New version of my custom firmware build: 1.0.4.32HF.
Changes (vs 1.0.4.31.1HF):
8. zlib package is optimized.
The link is:
Voxel
Voxel's picture
Changes (vs 1.0.4.32HF):
1. QoS DB is updated to v1.58
The link is:
Jlove3184
Jlove3184's picture
Hi.  Is this firmware more
Hi.  Is this firmware more stable than the current stock firmware?  I'm asking because on the current stock firmware I get constant disconnects when downloading large files such as 4K video downloads.  Thanks.
